sundogbrew's avatar
sundogbrew
Oct 20, 2022
radius irule for IPV6
Greetings, I am looking for some help here.  There are a few past posts about using an irule in your radius vip, I am wondering if anyone has used it for V6.
I was using
when RULE_INIT {
 array set ::attr_code2name {
         1     User-Name
         2     User-Password
         3     CHAP-Password
         4     NAS-IP-Address
         5     NAS-Port
         6     Service-Type
         7     Framed-Protocol
         8     Framed-IP-Address
         9     Framed-IP-Netmask
        10     Framed-Routing
        11     Filter-Id
        12     Framed-MTU
        13     Framed-Compression
        14     Login-IP-Host
        15     Login-Service
        16     Login-TCP-Port
        17     (unassigned)
        18     Reply-Message
        19     Callback-Number
        20     Callback-Id
        21     (unassigned)
        22     Framed-Route
        23     Framed-IPX-Network
        24     State
        25     Class
        26     Vendor-Specific
        27     Session-Timeout
        28     Idle-Timeout
        29     Termination-Action
        30     Called-Station-Id
        31     Calling-Station-Id
        32     NAS-Identifier
        33     Proxy-State
        34     Login-LAT-Service
        35     Login-LAT-Node
        36     Login-LAT-Group
        37     Framed-AppleTalk-Link
        38     Framed-AppleTalk-Network
        39     Framed-AppleTalk-Zone
        60     CHAP-Challenge
        61     NAS-Port-Type
        62     Port-Limit
        63     Login-LAT-Port
when CLIENT_ACCEPTED {
  if { ([UDP::local_port] != 1812) && ([UDP::local_port] != 1813) } {
   log local0. "packet on port [UDP::local_port] dropped"
   drop
  }else {
      set CALLID [RADIUS::avp 31 string]
      persist uie $CALLID
      log local0. "persisted $CALLID"
when CLIENT_DATA {
   if { [UDP::local_port] == 1813 } {
   set IP [RADIUS::avp 8 ip4]
   if { $IP != "" } {
       table set $IP [LB::server addr] 900
       log local0. "Radius maps $IP to [LB::server addr] for $CALLID"
when LB_SELECTED {
   log local0. "Selected [LB::server addr] [LB::server port]"
when SERVER_DATA {
   persist add uie $CALLID
   log local0. "persist added for $CALLID to [LB::server addr]"
So for V6, most of those attributes aren't in the packet, but I was figuring I could do persistance on NAS-IPv6-Address which shows up in the radius packet as 95.  AVP: t=NAS-IPv6-Address(95) l=18 val=xx:x:x:x::x:x
But if I add 95 NAS-IPv6-Address to the set command and try to call it, I get garbage in my output
<CLIENT_ACCEPTED>: persisted &ôp��������������Pp
It allows me to login but the persistance doesn't work.
Any help would be greatly appreciated!
Joe
  • it looks like whatever is being returned is binary and not a string. Two tangential recommendations as well:
    1. Don't use global variables, they demote all connections on that virtual server from CMP. Instead, convert ::attr_code2name to a static namespace variable: static::attr_code2name.
    2. Check to make sure the avp is present before acting on it like so:
    if { not ($CALLID equals "") } {
        persist uie $CALLID 900
