Technical Forum
Custom Alert Banner
Radius Authentication with Microsoft NPS and Azure MFA not working
Raghbir_Sandhu
Altocumulus
Altocumulus
We have configured F5 with Microsoft NPS to leverage Microsoft Azure AD MFA. F5 is sending Radius authentication request to Microsoft NPS server. However NPS server error. Looks like NPS server with Azure MFA extension expecting UPN value (john.smith@mydomain.com) but radius attribute User-Name is sending sAMAccount (or session.logon.last.username). The Microsoft Azure AD MFA is expecting UPN. I don't want to use the SAML based configuration.
Q: How do we extract / search for UPN value and assign it to radius attribute User-Name. I believe UPN value can be extract with LDAP Query but how to send UPN value in the radius authentication request. Any suggestion advise.
NPS serverError:
Log Name:   AuthZOptCh
Source:    Microsoft-AzureMfa-AuthZ
Date:     4/15/2021 5:06:35 PM
Event ID:   1
Task Category: None
Level:     Information
Keywords:
User:     NETWORK SERVICE
Computer:   123server.mydomain.com
Description:
NPS Extension for Azure MFA: CID: f6d91669-8579-4da0-8968-dfa4ea5ef928 : Request Discard for user Smith, John with Azure MFA response: InvalidParameter and message: UserPrincipalName must be in a valid format.,,,23090ad2-da92-4800-ae4c-8b59182f5fb7
F5 Radius tcpdump shows the following Radius authentication request with the sAMAccount (or session.logon.last.username) in the User-Name attribute:
RADIUS Protocol
  Code: Access-Request (1)
  Packet identifier: 0xab (171)
  Length: 74
  Authenticator: abd00d0218bc6541842a401dcfb64d52
  Attribute Value Pairs
    AVP: l=10 t=User-Name(1): johnsmith01
      User-Name: johnsmith01
    AVP: l=18 t=User-Password(2): Decrypted: Ajitkaur02@
      User-Password: xxxxxxxxx
    AVP: l=6 t=Service-Type(6): Authenticate-Only(8)
      Service-Type: Authenticate-Only (8)
    AVP: l=14 t=Tunnel-Client-Endpoint(66): 65.60.150.62
      Tunnel-Client-Endpoint: 65.60.150.62
    AVP: l=6 t=NAS-Port(5): 0
      NAS-Port: 0
1 ACCEPTED SOLUTION
which version are you on? I can see this feature from 13.x and onwards.
By default apm uses session.logon.last.username variable for username. See if you can set custom APM variable for it and change it to UPN variable you get after LDAP query.
9 REPLIES 9
SanjayP
MVP
MVP
Yes, you would need to perform LDAP query first and get the UPN. You can then use that UPN session variable in the radius auth item in VPE.
Raghbir_Sandhu
Altocumulus
Altocumulus
Sanjay. Thanks for the reply. How do i get username source and password source attributes in my radius AAA in VPE. how to add the two attributes.
when you select radius auth action in access policy those variables are added by default. You can read more below
https://techdocs.f5.com/kb/en-us/products/big-ip_apm/manuals/product/apm-authentication-single-sign-...
Sanjay, I don't see the additional two attributes. see the attached screenshot.
we are using 12.1.5.3. May be that's why I don't see two additional variables. what the question remain same. The radius request attribute name is "User-Name". can i just assign UPN value to the "User-Name" attribute via variable assignment step. before the MFA step. Please advise.
  • LDAP query to get UPN
  • Set custom variable for session.logon.last.username to UPN variable
  • Radius auth
Have you made this working? It would be good to share your solution, it may benefit others using similar setup. Thanks! ​
Yes. It is working. I ended up creating registry entry "LDAP_ALTERNATE_LOGINID_ATTRIBUTE". Some how our NPS not able to process the User-Name attribute properly passed from F5 Radius authentication request. That fixed our problem and I don't have to do the LDAP query for UPN attribute.
Thanks,
Raghbir Sandhu
