28-Feb-2021 13:29
Morning
I have a server configure for mTLS and I would like to be able to inspect the Client Certificate presented and reject if some criteria matches, preferably via Proxy SSL.
However from what I am seeing it looks like that the F5 LTM cannot see the handshake and therefore reject during negotiation. I am assuming that this is what is meant by application traffic, i.e non handshake traffic.
Is there a way I can keep client authentication on the backend server and still intercept the client SSL handshake so that I can perform a reject.
The reason is that I have a large number of clients out there that I need to do an IP check against based on details in the subjectdn of the client certificate. I.e I take a value from the dn and use it to lookup a value and reject if not valid.
I need to keep the client cert and pass it down to an AMQP instance as it is configured for client certificate authentication.
Could I for example generate a cert on the fly to pass through to the backend server? Or is there a better way to do this?
Nicholas
01-Mar-2021 01:12
The method for passing through Client Certificates to the backend server is called C3D https://support.f5.com/csp/article/K14065425
01-Mar-2021 17:34
