15-Jun-2023 22:09
Is it advisable to provision r2600 equipment with LTM, DNS, AWAF + IP intelligence licensing? o for 3 or more provisioned modules, higher equipment such as r4xxx must be used?
Solved! Go to Solution.
16-Jun-2023 06:05
In my lab, if I want to use ALL modules, then I provision 8core+16Gb. This is a lab with automation, couple dozen apps and minimal client traffic.
The r2600 has 8 cores and 32Gb ram. So, to answer you question, I don't think you will have any problems running those services on that hardware. However, I would be very cautious about how much client load you put on the box and particularly how comprehensive the AWAF policies are.
I suggest reaching out to your account team for a deeper analysis and capacity planning.
16-Jun-2023 06:05
16-Jun-2023 06:44
Thank you, Ben_Novak
20-Jun-2023 16:26
I've pro-actively marked @Ben_Novak 's answer as Solution. If you disagree @Johana23 - feel free to un-select / provide some additional context to help others help. Thanks, Lief
