02-Mar-2020 04:10
Hello,
I need to upgrade viprion VCMP host to a new version. However the Install configuration option is greyed out and I found this article https://support.f5.com/csp/article/K14724.
Is this the only command I need?
eg.
clsh cpcfg --source=HD1.2 --reboot HD1.3
I have upgraded VCMP guests (viprion) and they copy the config over to a new partition even if the install config is greyed out and left to No. I just want to be sure that everything goes well for the VCMP host system.
BR
Teemu
02-Mar-2020 04:58
While you installing a BigIP version in a target partition, by default, current config in current partition will also be loaded in to target partition.
On GUI, when you try to boot into target partition, you will have another chance to push current partition config in to target partition. This is helpful if config has changed since the installation and there is a need to push latest config.
Using the feature on GUI will over write the config pushed previously while installing.
Therefore, even if "Install Configuration" option is greyed out at the time of booting, you can ignore it you will still have the config pushed at config installation.
Hope this helps,
Nag
02-Mar-2020 05:05
What do you mean by the config pushed at config installation? "you will still have the config pushed at config installation"
Is this the time when the software image is installed or latest config save?
BR Teemu
02-Mar-2020 05:18
In Viprion, Install Configuration is greyed out by design, I upgraded one of the guest in my viprion device last week and it upgraded without any issue. clsh cpcfg helps to identify if there is some issue in the config before reboot.
02-Mar-2020 05:22
Okay. Maybe ill go with clsh cpcfg to make sure everything is ok.
02-Mar-2020 08:42
Should the guests be put to provisioned or configured state?
