24-May-2020 18:33
hi, i have a problem trying to sync a cluster f5 ssl orchestrator. It turns out that the configuration is guided by the wizard, where you create the service chain and others, but I do it in the active one and then I cannot synchronize due to an error that it cannot find the VLAN, what should I do in that case?
