Priority Activation Group - Revert back to top group
matnetmin
Complete newbie question here.
I have a pool with 4 nodes as per setup
Node 1 - PAG 100
Node 2 - PAG 100
Node 3 - PAG 50
Node 4 - PAG 50
When we have Node 1 & 2 Down, Node 3 and 4 display a site offline page, which works great.
When Node 1 and 2 come back online, we are still using node 3 and 4, not so great.
I have also tried to get around this by removing nodes 3 and 4 and creating a 2nd pool with them, then using the following iRule
  if {[active_members [LB::server pool]] < 1 } {
    pool Pool-2
Now the VIP does have a cookie insert persistence profile, which i think may be where i am getting stuck
What would be the best way to do this, without loading the page into iFiles.
1 REPLY 1
Simon_Blakely
F5 Employee
F5 Employee
With that irule, do you have a OneConnect profile attached to the virtual?
The OneConnect profile ensures that you make a new load-balancing decision on every HTTP Request, and not just the first one.
Otherwise, you need to use a LB::detach in HTTP_RESPONSE.
