Technical Forum
Custom Alert Banner
Preserve Original Source IP thats not just Web Traffic
rmoss25
Altostratus
Altostratus
Is there a way to preserve the original source IP of traffic passing through an LTM Virtual server? We have enabled the Insert X-Forwarded-For option in the HTTP profile and while this works for web traffic we have other traffic hitting the virtual servers that are outside of web traffic and need a way to preserve the source IP for incident handling purposed.
thanks
2 REPLIES 2
eey0re
Obviously other protocols don't have "X-Forwarded-For", so the only way to preserve the source IP is to actually preserve the source IP: turn off SNAT in the Virtual Server so that the source address is not translated.
This is a "routed" configuration, rather than a "SNAT" configuration, and means the backend server will see the connection as from the real client IP.
  • All the return traffic still needs to pass back through the BIG-IP, so the backend server must now use the BIG-IP's floating Self IP as its gateway. (For Internet traffic, this generally means the BIG-IP becomes the server's default route.)
  • The backend server therefore needs to be on the same subnet as a BIG-IP Self IP to be able to use it as a gateway.
  • The server still needs to be able to reach everything else that didn't come via the Virtual Server. Usually this means:
    • some more specific routes on the server to keep using its regular router, and/or
    • a wildcard Virtual Server on the BIG-IP of type "Forwarding (IP)" combined with appropriate routes on the BIG-IP so it knows where to forward to.
As you can see this is quite a different design. For more information see About Virtual Servers in the BIG-IP Local Traffic Management: Basics manual.
For SMTP there is a posible solution as it is similar to HTTP as it also has headers:
https://devcentral.f5.com/s/question/0D51T00006i7N6U/adding-xheader-to-smtp
For DNS there is th EDNS Client Subnet:
https://devcentral.f5.com/s/articles/using-client-subnet-in-dns-requests-31948
