Techgeeeg_28888's avatar
Techgeeeg_28888
Nov 07, 2017
Port Lock Down on MGMT Port
Hi Everyone, To all the experts out there I would like to ask a question related to the Port Lock Down on MGMT port. Is there a way we can do the port lock down on F5 MGMT port to allow only selected ports.
Regards,
    • Techgeeeg's avatar
      Techgeeeg
      Hi Eben,
      Thanks for your reply I came across this article but what I exactly want to know is that like the TMM Switch ports do we have the facility of port lock down on the MGMT port.
      Regards,
      Techgeeeg
      Hi Eben,
      Regards,
    • eben's avatar
      eben
      Hi Techgeeeg,
      At the moment, No.
      Regards.
  • if you enable AFM you can set an access rule (with for example ports) on the management interface.
    but why do you want to? you can lock down SSH already built in and for the rest you have https left. if you don't want that just don't use the management interface.
