Kalpesh_48932's avatar
Kalpesh_48932
Jul 09, 2012
Port forwarding for SMTP
Hello,
i have done port forwarding for SMTP traffic. for this I have configured VIP on port 25 and pool members of this VIP on port 2500.
however when i test i get this TWO below diff results.
1. ON DIRECT NODE :
$ telnet 10.155.63.126 2500
Trying 10.155.63.126...
Connected to A92SV00699JIV (10.155.63.126).
Escape character is '^]'.
220 localhost ESMTP SubEthaSMTP
HELO domain
250 localhost
QUIT
221 Bye
Connection closed by foreign host.
2. VIA VIP :
$ telnet 10.155.65.43 25
Trying 10.155.65.43...
Connected to uat.my.saint-gobain.com (10.155.65.43).
-------------- here “220 localhost ESMTP SubEthaSMTP” is missing !!!!!!!!!!!!!!!!!!!
HELO domain
250 localhost
QUIT
-------------- here no reaction/resonse from the node
can anyone please help?
  • 2. VIA VIP :
    HELO domain
    250 localhost
    QUIT
    -------------- here no reaction/resonse from the node is 220 not a line below HELO domain??
    this is my testing.
    [root@ve10:Active] config  b virtual bar list
    virtual bar {
       snat automap
       pool foo
       destination 172.28.19.79:25
       ip protocol 6
    [root@ve10:Active] config  telnet 172.28.19.79 25
    Trying 172.28.19.79...
    Connected to 172.28.19.79 (172.28.19.79).
    220 mail.f5.com ESMTP
    HELO me
    250 mail.f5.com
    QUIT
    221 mail.f5.com
  • Hi Nitass
    if you see both outputs you can find difference in sequence.
    220 should be above HELO domain.
    after QUIT command 221 sequence of aborting is missing.
  • 220 should be above HELO domain. sorry i might misunderstand i.e. i thought you typed HELO too fast.
    e.g.
    HELO me
    250 mail.f5.com
    anyway, if it is not, is there any special setting in the virtual server configuration?
  • This is the current setting I have on F5.
    [root@STG1F5LDB01:Active] config b virtual vs_jive_uat_25 list
    virtual vs_jive_uat_25 {
    snat automap
    pool pool_jive_uat_25
    destination 10.155.65.43:smtp
    ip protocol tcp
    profiles {
    http {}
    tcp {}
    vlans INTERCO enable
    [root@STG1F5LDB01:Active] config b pool pool_jive_uat_25 list
    pool pool_jive_uat_25 {
    members {
    10.155.63.126:rtsserv {
    priority 5
    10.155.63.153:rtsserv {
    priority 1
    session user disabled
  • why do you use http profile for smtp traffic? does it really work??
  • I tried removing HTTP profile.
    snat automap
    ip protocol tcp
    and after this, when i tested, connection drops immediately.
    Can you tell me tcpdump command to display capture during test? I want to test connection on VIP.
    i tried below and did not had anything in capture.
    [root@STG1F5LDB01:Active] config tcpdump -s0 dst 10.155.65.43 and dst port 25
    tcpdump: WARNING: eth0: no IPv4 address assigned
    tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
    listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
    0 packets captured
    10 packets received by filter
    0 packets dropped by kernel
  • Can you tell me tcpdump command to display capture during test? I want to test connection on VIP. can you try this?
    to screen
    tcpdump -nni 0.0 \(host 10.155.65.43 and port 25\) or \(host 10.155.63.126 or host 10.155.63.153 and port 2500\)
    to file
    tcpdump -nni 0.0:nnn -s0 -w /var/tmp/output.pcap \(host 10.155.65.43 and port 25\) or \(host 10.155.63.126 or host 10.155.63.153 and port 2500\)
