Technical Forum
Pool Member Status and how QTYPE works?
NetSnoopy
Cirrus
Cirrus
Hello,
i wrote a small Irule for show the Pool Member status as json.
when HTTP_REQUEST {     if { [string tolower [HTTP::host]] eq "f5_status.XXXX.com" } {         #update Poollist, enter Pool names         set poolname "P_X_http80 P_XX_http80 P_XXX_https6443"          #update RootPartition for replacement         set stringmap "\"%1234 \" \"\:\""         set poolnummer 1         set json "\{\"status\"\:\{\"time\"\:\"[clock format [clock seconds] -format "%Y-%b-%dT%H:%M:%S %Z"]\","         foreach pool_n $poolname {             set list_all ""             set list_up ""             set list_down ""              set member ""             set member_l ""             foreach member [members -list $pool_n ] {                 set member_l "[string map $stringmap $member]"                 append list_all "\"$member_l\","             }             set member ""             set member_l ""             foreach member [members -list $pool_n ] {                 if { !([active_members -list $pool_n ] contains $member) }{                     set member_l "[string map $stringmap $member]"                     append list_down "\"$member_l\","                 }             }             set member ""             set member_l ""             foreach member [active_members -list $pool_n ] {                 set member_l "[string map $stringmap $member]"                 append list_up "\"$member_l\","             }             set count_a [active_members $pool_n]             set count [members $pool_n]             set count_d [expr {$count} - {$count_a} ]             append json "\"pool$poolnummer\"\:\{\"name\"\:\"$pool_n\",\"member count active\"\:$count_a,\"member count down\"\:$count_d,\"member count all\"\:$count,\"member active\"\:\[[string trimright $list_up ","]\],\"member down\"\:\[[string trimright $list_down ","]\],\"member all\"\:\[[string trimright $list_all ","]\]\},"             incr poolnummer         }         set json [string trimright $json ","]         append json "\}\}"         HTTP::respond 200 content "$json" "Content-Type" "application/json"     } }
But i found that new implementation
#v12 change to include QTYPE members [-list] [QTYPE] <poolName> [blue green yellow red gray]
https://clouddocs.f5.com/api/irules/members.html or https://clouddocs.f5.com/api/irules/active_members.html
Anyone know how this work or have a working irule with this "qtype"? I would like to see a example!
1 REPLY 1
cjunior
Nacreous
Nacreous
The QTYPE param is exclusive for GTM pool and used on GTM iRules.
When not defined, QTYPE has "A" as the default value.
Note: GTM does not support the -list option
e.g.
https://clouddocs.f5.com/api/irules/DNS_REQUEST.html
when DNS_REQUEST { # Changed = = 0 to < 1 for CR100063 / SOL10137 if { [active_members pool_test] < 1 } { cname "something.domain.com" } }# Similar if { [active_members A pool_test] < 1 } {
Regards.
