Technical Forum
Please help with irule for pool selection based on custom http header
sandman748
Hi all,
Could someone assist me with an irule that would look at a custom header callled X-Server-Pool. If "xyz" then this pool, if "abc" then this pool, else default.
I think this is a starting point but it doesnt appear to be working
  1. when HTTP_REQUEST {
  2. if { [HTTP::header exists X-SERVER-POOL] and [HTTP::header X-SERVER-POOL] equals "xyz" } {
  3. pool xyz
  4. } elseif [HTTP::header exists X-SERVER-POOL] and [HTTP::header X-SERVER-POOL] equals "abc" } {
  5. pool abc
  6. }
  7. }
  8. }
If no header exists it would hit default pool assigned to vip?
1 REPLY 1
Hi sandman748,
Can you look logs with this:
when HTTP_REQUEST { if { [HTTP::header exists X-SERVER-POOL] } { log local0. "X-Server-Pool: [HTTP::header X-SERVER-POOL]" switch [HTTP::header X-SERVER-POOL] { "xyz" { pool xyz } "abc" { pool abc } } } }
If no header exists, it hits the default pool. If no default pool exists, it drops. You can add default pool configuration in iRule with using else or switch.
when HTTP_REQUEST { if { [HTTP::header exists X-SERVER-POOL] } { log local0. "X-Server-Pool: [HTTP::header X-SERVER-POOL]" switch [HTTP::header X-SERVER-POOL] { "xyz" { pool xyz } "abc" { pool abc } default { defaultpool } } } }
