12-Aug-2020 07:28
We have a old Plattform BIG-IP 3600 with the lastest SW-Version 12.1.2.2.0.276-HF and isn't possible according to the matrix HW matrix (https://support.f5.com/csp/article/K9476) to changing the SW-Version.
Is there a separate patch planned for this version?
On the side https://support.f5.com/csp/article/K52145254 find the column "Versions known to be vulnerable" with entry "12.1.0 - 12.1.5".
How can i patch the system without the HW Change?
Is there another possibility?
BR Robert
Solved! Go to Solution.
12-Aug-2020 09:31
Unfortunately, you will have to apply the patch manually, via the below link.
Our official site is: https://support.f5.com/csp/article/K52145254
12-Aug-2020 09:31
