08-Dec-2020
04:08
- last edited on
04-Jun-2023
21:09
by
JimmyPackets
Hi
How to assign an iRule to a virtual server in iApp template
I created iapp for owa 2010 using: f5.microsoft_exchange_2010_2013_cas.v1.6.2 , with APM authentication before
but the logout function is not working
when users click logout they don't actually logout
So i'm trying to add this irule to the VS created automatically by iapp , but without succeeding and getting this error message:
010715bc:3: The application service (/Common/owame.app/owame) has strict updates enabled, the object (Virtual Server /Common/owame.app/owame) must be updated using an application management interface.
This is the irule:
set apm_cookie [HTTP::cookie value MRHSession]
if { ([HTTP::uri] contains "logoff") } {
log local0. "logoff triggered"
HTTP::respond 302 noserver "Location" "/vdesk/hangup.php3?hangup_error=1" "Content-Type" "text/html" "Cache-Control" "no-cache, must-revalidate" Set-Cookie "MRHSession=deleted;expires=Thu, 01-Jan-1970 00:00:10 GMT;domain=[HTTP::host];path=/" Set-Cookie "LastMRH_Session=deleted;expires=Thu, 01-Jan-1970 00:00:10 GMT;domain=[HTTP::host];path=/"
log local0. "Session removed"
if { ([ACCESS::session exists -sid $apm_cookie]) } {
ACCESS::session remove
log local0. "Access Session Removed"
Solved! Go to Solution.
08-Dec-2020 04:34
Hello,
The Strict Updates option is enabled by default on deployed iApp template. This is for protection against any kind of accidental changes to an iApp. If you want to make any changes to it e.g. adding iRule in your case, you need to disable Strict Updates and then make changes. DO NOT FORGET to Re-enable the Strict Updates again post adding iRule.
NOTE - It is recommended to keep the Strict Updates setting enabled and make any changes to the iApp's configuration by modifying the template. But if its not possible to modify it directly, you can disable settings for time being. This shouldn't cause any negative impact on the traffic.
Strict Updates setting is available under --> iApps -->Application Services -->Properties-->Advanced
Hope it helps!
08-Dec-2020 04:34
Hello,
Hope it helps!
