03-Nov-2022 11:11
Hello there
We have a problem where, at some times the order of cookies in the package are reversed, I wonder if there is an irule to reverse cookies, making the application cookie available before the F5 cookie? It's possible?
Solved! Go to Solution.
13-Nov-2022 04:12 - edited 13-Nov-2022 04:12
Hi @EduardoSousa,
you somehow did not mention in which direction you want to reverse the cookie order. From BIG-IP to browser, or from BIG-IP to backend server. Hence I presumed you want to reverse the order from BIG-IP to backend server.
Here is my iRule:
when HTTP_REQUEST_RELEASE {
# Remove Cookie by name
HTTP::cookie remove "BIGCookie"
# Reverse order of Cookies
if { [HTTP::header exists Cookie] } {
set cookie_rev {}
set values [split " [HTTP::header Cookie]" ";"]
set i [llength $values]
while {$i} {lappend cookie_rev [lindex $values [incr i -1]]}
set cookie_fini [join $cookie_rev ";"]
HTTP::header replace Cookie "$cookie_fini"
unset cookie_fini
unset cookie_rev
Browser to BIG-IP:
BIGCookie is removed, order is reversed.
Does this solve your issue?
Note: The order of cookies usually should not be an issue. In my opinion reversing the order is not required. Maybe you can explain us, why you have this requirement?
KR
Daniel
Hi @EduardoSousa,
Here is my iRule:
set cookie_rev {}
unset cookie_fini
unset cookie_rev
Browser to BIG-IP:
KR
Daniel
13-Nov-2022 04:52
@Daniel_Wolf wrote:Note: The order of cookies usually should not be an issue. In my opinion reversing the order is not required. Maybe you can explain us, why you have this requirement?
For the sake of completeness - how did I come up with this opinion:
14-Nov-2022 13:39 - edited 14-Nov-2022 13:40
and the RFC in support of that as well on field order with HTTP...if @Daniel_Wolf's response was helpful to you, can you mark it as solved, @EduardoSousa? Thanks...Jason
14-Nov-2022 13:44 - edited 14-Nov-2022 13:44
Hi @Daniel_Wolf and @JRahm yes, thanks for the help.
