Bret_McGinnis_1
Aug 02, 2005Nimbostratus
Number of defined nodes in a pool
Is there a way in irules to determine the number of defined nodes in a pool. I'm trying to automate syslog notification when a pool is getting low on nodes. The number of active node is good but I need the context of how many nodes are in the pool. I would take a different action if I have 3 or 20 nodes active then I would if I have 3 out of 4 nodes active.
thanks
