First, you can upload your F5 QKview on iHealth and select version of software you are considering upgrading to from the drop-down menu of "Upgrade Advisor" and see the Upgrade Advisor feedback before start you migration.
Then, a config check on all F5 units in order to verify that all bigip.conf are clean/safe before the upgrade :
tmsh load sys config verify
For the migration part of F5 appliance hardware to F5 VE, ask may have a chat with your F5 sales team or and F5 partner to study the best vcpu/memory sizing of your futur VMs.
You can also use the F5 Migration Assistant Tool or play with the UCS archive 'platform-migrate' option to make your UCS backups
- Nathan_F__F5_Employee
Hello,
I would agree with Lidev's response but would also like to add a couple of things. First, unfortunately it looks like v13.x is not supported on the 3900 platform so you may want to choose a different software version to upgrade to. Please see the following article about this.
K9476: The F5 hardware/software compatibility matrix
https://support.f5.com/csp/article/K9476
With that said, we do have another article that should be helpful and covers just about everything related to upgrades. It can be found at the link below.
K84554955: Overview of BIG-IP system software upgrades
https://support.f5.com/csp/article/K84554955
-Nathan F
- Harishwar_Redd2Nimbostratus
we are doing manually starting from Scratch.
