girishb's avatar
girishb
Icon for Cirrus rankCirrus
Jan 25, 2020
Need Help to create an iRule for Name Based Virtual Hosting
We are trying to build iRule for one newly build tomcat server when the F5 picks one of the new pool members, the iRule needs to route the request, in a round robin manner, to the different instances of the application on the same VM/IP.
So for example, when picking 10.1.1.1443 it needs to then route to either 1perf.cloud123.com and 1perf.cloud123.com and so on.
VIP-PRF -> VIP
VIP-PRF _POOL -> Pool Members
             10.1.1.1:0 -> Legacy
             10.1.1.2:0 -> Legacy
             10.1.1.3:443 -> New tomcat
               1perf.cloud123.com -> Instance of the new application
               3perf.cloud123.com-> Instance of the new application
             10.1.1.4:443 -> New tomcat
             2perf.cloud123.com -> Instance of the new application
               4perf.cloud123.com-> Instance of the new application
We tried create iRules but its not allowing to create ( refering this devcentel link.:
https://devcentral.f5.com/s/articles/name-based-virtual-hosting-with-ltm)
I need your help to create iRule based name based virtual hosting on VIP
Great thanks in advance
  • Hosting multiple websites on the same virtual server and load balancing requests to the appropriate webserver based on the host name requested. This can be achieved via iRule or F5 policy also.
    ** Make sure IP address bind with multiple DNS CNAME.
    * Create the LB Pool based on the application requirement.
    Pool_A[ 1perf.cloud123.com,   3perf.cloud123.com]
    Pool_B [  2perf.cloud123.com,   4perf.cloud123.com]
    * Create iRule
    set host [string tolower [HTTP::host]]
    switch -glob $host {
          "www.xyz.com" {
             pool pool_A
          "www.pqr.com" {
             pool pool_B
         default { reject }
    * Create the Virtual Server and assign irule.
    Hope it will solve issue.
  • Hi Samir, Great Thank for your details.. you added correct details :)
    I just wanted to added few more details..
    there is an existing VIP : VIP-PRF, there were two new AWS servers added 10.1.1.3 and  10.1.1.4 to this Pool Member which are Name Based Nodes . so the request here is like no changes should be made to the existing Pool members and for New Pool members we need to have the traffic going :
    if URI contains Web2 then request to the Node : 10.1.1.4 should have Header Insertion as   2perf.cloud123.com and   4perf.cloud123.com
    and if if URI contains Web1 , Then request goes to 10.1.1.3 then it should have Header insertion as 1perf.cloud123.com and  3perf.cloud123.com.
    So backend Server look into this endpoint in server code so later on re-direct further on
