Aj2's avatar
Aj2
Feb 15, 2023
Need Help for iRule
Need Help to write irule :
Redirects are for HTTP requests made with a path prefix matching https://xyz.test.com/age/signup.
Matching requests should be redirected to https://abc.test.com/#/inSign/invite,
Additionally, a new query parameter should be appended to the resulting URL: account=xyz
The redirected request should include the query parameters supplied from the original request before the redirect.
  • Aj2 This should do exactly what you would like for the hosts and uri paths provided.
    when HTTP_REQUEST priority 500 {
        set HOST [HTTP::host]
        set URI [string tolower [HTTP::uri]]
        if { ((${HOST} == "xyz.test.com") && (${URI} == "/age/signup")) } {
            HTTP::redirect "https://abc.test.com/#/inSign/invite?account=xyz"
    • Awesome Paulius ,
      I will add an info for you , its highly recommended to give up using variables in your Scripts , and use it when you have to use it only.
      that's for performance concerns.
      • Mike757's avatar
        Mike757
        Icon for MVP rankMVP
        Not sure in this case, Mohamed...
        I get a feeling the example is more general, and variables would be needed. When Aj2 wrote "zyz" I imagine it may take up any value.
        Aj2, can you confirm the need for string replacement in your request? Or did Paulius answer your needs 100%?
        /Mike
