24-Jan-2020 04:30
Hi team,
Initially I have configured forward proxy without any issue:
Client (Intranet) -> F5 (explicit-http) -> INTERNET
Now, we want to put proxy pool between F5 and INTERNET like this:
Client (Intranet) -> F5 (explicit-http) -> HTTP Proxy Pool -> INTERNET
I tried to follow this article - https://devcentral.f5.com/s/articles/configure-the-f5-big-ip-as-an-explicit-forward-web-proxy-using-... , however F5 (explicit-http) doesn't seem to tunnel the traffic to the HTTP Proxy Pool.
Please guide me what is missing?
Thanks,
Riwut
Solved! Go to Solution.
24-Jan-2020 11:34
Have you seen this iApp? May identify any misconfiguration. Of course you may not need to go down the route of 0365 bypass though.
24-Jan-2020 11:34
25-Jan-2020
18:41
- last edited on
24-Mar-2022
01:07
by
li-migration
thanks, you are saving my day.
For others who has same difficulties, here are the key moving part to create load balance forward proxy chain.
Apparently my initial configuration was missing step-4 (disable one connect transformation) and step-5 irule.
Hence the principle to achieve forward proxy chain are:
Thanks,
Riwut
30-Jan-2020
15:54
- last edited on
24-Mar-2022
01:07
by
li-migration
- might you consider selecting the answer that provided as best? You could select your own as well if you prefer. Cheers.
