Deepak_Nair's avatar
Feb 17, 2021
Need a HELP with my IRULE
Hi Folks ,
I am working on one requirement and need a little help with my Irule .
When CLIENT makes a req with https://example.com/abcserver and hit to F5 , the F5 should send a response as https://example.com/abcserver/rest/services . I am able to achieve this part through re-direction ( But i am not sure if this is the correct way of doing this ) .
After that the F5 should do a GET request to backend server as below :
GET xyz or GET xyz/rest/services to the backend server
I have written this irule , re-direction is working BUT not able to GET the content .
if {([string tolower [HTTP::host]] equals "example.com") && [HTTP::uri] starts_with "/abcserver" } {
 HTTP::redirect "https://example.com/abcserver/rest/services
 HTTP::uri [string map [list "/abcserver" ""] xyz/[HTTP::uri]]
     node 1.1.1.1 6443
I think my this irule ends up in too many re-direction . I am NOT able to understand how to achieve the GET part through irule once re-direction is DONE.
IS this the right way of doing this through re-direction .
Any help in this regard is greatly appreciated .
Thanks .
  • Ok , i tweak by irule and able to load the page , BUT response to CLIENT is not what is expected . i have removed the redirect statement under the irule .
    This is how my irule looks now .
      HTTP::uri "/xyz/rest/services"
          node 1.1.1.1 6443
    The CLIENT is expected to see in the browser https://example.com/abcserver/rest/services
    when request is made with https://example.com/abcserver
    i am not able to achieve this . Any help in this regard greatly appreciated .
  • I see you are using starts_with, which will match all time. Try equals.
    if {([string tolower [HTTP::host]] equals "example.com") && [HTTP::uri] equals "/abcserver" } {
    HTTP::redirect "https://example.com/abcserver/rest/services"
    if {([string tolower [HTTP::host]] equals "example.com") && [HTTP::uri] equals "/abcserver/rest/services" } {
    HTTP::uri [string map {"/abcserver" "/xyz"} [HTTP::uri]]
    node 1.1.1.1 6443
    So once its redirected, the request is going to come in with /abcserver/rest/services, then on the second condition you can make that check & modify your GET request.
