AlexS_yb's avatar
AlexS_yb
Aug 28, 2021
My stick session
Hi
The system has multiple tomcat stype containers, they provide a JSESSIONID and we append a node id to the end
so we have a JSESSION id that looks like
JSESSIONID=83987345.nodeX where X could 1 2 3 4 5
on my nginx setup i had
 server app1.env:XXXX slow_start=0s weight=1 max_fails=0 fail_timeout=10 route=node1;
 server app2.env:XXX slow_start=0s weight=1 max_fails=0 fail_timeout=10 route=node2;
  # Session Persistence based on JSESSION ID, if necessary
  sticky route $route_cookie;
# jboss mapping for nodes
map $cookie_jsessionid $route_cookie {
  ~.+\.(?P<route>\w+)$ $route;
I want to do this in F5 i presume with F5.
But ... the persistence model in F5 break my nginx setup.
so
client A -> connect talks to node1
JSESSIONID 123456789.node1
node1 dies
client A -> get rerouted to node2
JSESSIONID 123456789.node1...
JSESSIONID 987654321.node1
note 100% sure if the jsessionid changes or not. but i'm 100% sure that the nodeX stays the same
until node1 comes back client gets routed to node2
once node1 comes back the client is routed back to node1
I presume irule.
but how do I say go to pool member if its up otherwise go to pool (use the balancing method)
  • Hello Alex.
    You could configure an iRule that routes traffic base on the "nodeX" value of the JSESSIONID cookie, checking first if this specific member is UP using "active_members" command.
    https://clouddocs.f5.com/api/irules/active_members.html
    Config details.
    • Create an iRule
    • create a generic pool with all members
    • create specific pools with only one member (let say, node1, node2, ...)
    iRules steps:
    1. Get the "nodeX" value.
    2. if "[active_members pool_nodeX] == 0" use generic pool
    3. if "[active_members pool_nodeX] > 0" use specific pool (pool_nodeX)
    Hope this helps you.
    Regards,
    Dario.
  • xuwen's avatar
    xuwen
    pool_node1 member 10.1.1.10:80 monitor tcp
    pool_node2 member 20.1.1.20:80 monitor tcp
    pool_default member 10.1.1.10:80 20.1.1.20:80 monitor tcp
    iRuels code:
    when RULE_INIT {
      array set static::pool_array {
        1 pool_node1
        2 pool_node2
      if { [HTTP::cookie exists "JSESSIONID"] } {
        set node_x [findstr [HTTP::cookie "JSESSIONID"] "node" 4 1]
        log local0. "node_x is $node_x"
        if { [active_members [lindex [array get static::pool_array $node_x] 1]] == 0 } {
          pool pool_default
          pool [lindex [array get static::pool_array $node_x] 1]
        pool pool_default
    • AlexS_yb's avatar
      AlexS_yb
      Think I like this. but modified
      I will create singleton pools for each member and 1 pool with all members.
      then
      if I have no JSESSIONID or no NODE
      then go to the generic pool
      other wise
      test to see if pool with 1 node corresponding to the NODE1 is available
      if yes then send it
      if no then send to generic pool
