20-Feb-2021 04:09
Hi All, we have some monitors on our f5 to monitor a web page and look for a response to ensure it is running.
An example of one that works on our system uses the syntax below,
GET / HTTP/1.1\r\nHost: test.test.com\r\nConnection: Close\r\n\r\n
We need to monitor a site that uses the below webpage , however it does not work, can someone help me to correct the syntax
https://xxxx.xx.local:8443/tc/controller/test
and the response to he site should be
###### This is presentation tier test page!! ######
Can someone tell me what I need to change?
20-Feb-2021 06:20
Something like below should do the work,
create ltm monitor https TEST-HTTPS { interval 30 timeout 91 send "GET /tc/controller/test HTTP/1.1\\r\\nUser-Agent: BigIP Prober\\r\\nHost: test.test.com\\r\\nConnection: close\\r\\n\\r\\n" recv "This is presentation tier test page" recv-disable "Drain" }
