20-Sep-2017 03:41
Hi -
I would be grateful for some guidance on the following in relation to BIG-IP version 11.4.1 HF7.
The requirements is to create a monitor that checks for the existence of a File on two members.
If the File exists, traffic is routed to one or both members.
Investigation thus far suggests that the appropriate monitor is type "SMB"?
Further, the in-built SMB monitor appears to be sufficient? (as opposed to coding an external monitor).
However, I am unsure on how to specify some of the input parameters on the LTM SMB monitor GUI panel
•User Name & Password: In this case, I don’t think this is required.
Instead, I think that the BIG-IP Self-IP addresses require access to the folder on the end application servers
•The full Path / Filename: This will be of the form: /D$/LoadBalancing/Queryable.txt ; where “D&” represents the “D” drive on the application server
I am confused on what to input into the following two fields:- SMB/CIFS Server and Service Name.
I have the IP address of the two application nodes.
Do I specify these in SMB/CIFS Server or Service Name ?
If the IP address is specified SMB/CIFS Server, what should be specified within Service Name?
Much appreciated
