Sort By
- dennypayneEmployeeNot really within the base HTTP monitor type. You could either create 2 separate monitors and require that the pool members pass both of them with the Availability Requirement setting set to All (default - under Advanced in the Pool dialog), or you could create a scripted monitor (External type) that would use curl and parse the result for the codes you want to see.
- dennypayneEmployeeActually I misspoke, for your scenario with the 2 monitors I would set the pool's Availability Requirement to At Least 1, not All. That way either the 200 or the 503 response would result in success.
- hooleylistCirrostratusI think the receive string is evaluated as a regular expression. So you could potentially set the receive string to something like:
- Pankaj_71762NimbostratusThanks Alot. It works good.
