Joseph_Goyette_'s avatar
Joseph_Goyette_
Mar 10, 2005
Modify URI passed to servers ?
Howdy. I've a quick question to ask regarding iRules...
Is is possible to identify urls of the form:
http://thisismysite.com/aDirectory/aScript?par1=Type125&par2=2 etc...
Modify them to a slightly different form:
http://thisismysite.com/Type125.jsp?par1=Type125&par2=2 etc..
And then hand the modified url off to a pool of web servers ?
Issuing a redirect with the new url is one way to do this but I need to find a way to do it without issuing redirects (the tools calling the url's do not handle redirects).
Thanks !!!
Joe
  • drteeth_127330's avatar
    drteeth_127330
    Historic F5 Account
    Yes, iRules can do that. The HTTP::uri command with no arguments returns the URI. HTTP::uri rewrites the request URI to the specified value.
  • Excellent ! Now, is this same functionality supported on the 4.5.10 software version ? We run a mixture of older and newer F5 units.
    Joe
