Technical Forum
migration 6900F to i2800
Edwin_Bompart
it is possible to migrate configuration even though they are 2 different appliance?
1 REPLY 1
Shaun_Simmons
F5 Employee
F5 Employee
Yes, with a caveat 🙂
  • Depends which version of TMOS you have and what you are going to migrate.
If the TMOS versions are too different (EX: 11.x versus 14.x), even if the configuration is imported, you might potentially receive an error.
The best way to export and import a configuration is via SCF: https://support.f5.com/csp/article/K13408
