28-Sep-2022 22:09
Hi -
i have a vcmp guest which i need to move to a new F5 - and due to high resource requirement i want to move it to a physical F5 . would i follow the same steps to do ucs restore with platform migrate and no license checks
load /sys ucs <filename> platform-migrate
thanks
29-Sep-2022 11:25
Using the platform-migrate option should work pretty well. As the KB article states, you will probably need to reconfigure the networking and other things to get the system completely functional. I have had luck using methods like this in the past to migrate the standby unit and perform a manual failover to move to the new system.
K82540512: Overview of the UCS archive 'platform-migrate' option
