Joseph_Goyette_'s avatar
Joseph_Goyette_
Mar 28, 2005
matchclass + IP::remote_addr ?
Hi there,
I'm experiencing some odd behaviour when I attempt to develop an iRule that contains both a uri match and remote ip address check. The irule is below.
The odd behaviour appears as a "Document Contains No Data" popup message on my browser or a "page cannot be displayed" message whenever any of the ip address checks is TRUE and I've started my url with /CustomerX/ . The other redirect sections and the /junk/ check work as expected.
 when HTTP_REQUEST
    if {[HTTP::uri] starts_with "/junk/"} {
       pool JOE-web003
    elseif {[HTTP::uri] starts_with "/CustomerX/"} {
       if { [matchclass [IP::remote_addr] equals $::block1] } {
          pool JOE-web003
       elseif { [matchclass [IP::remote_addr] equals $::block2] } {
          pool JOE-web003
       elseif { [matchclass [IP::remote_addr] equals $::block3] } {
           pool JOE-web003
       else {
          HTTP::redirect "http://www.cnn.com/"
    else {
       HTTP::redirect "http://www.goyette.net/"
Has anyone here seen this type of behaviour before ? Is my rule constructed correctly ?
Thank you for any help !
Joe
  • unRuleY_95363's avatar
    unRuleY_95363
    Historic F5 Account
    Joe,
    I do not see anything specifically wrong with your rule.
    However, you may be running into a run-time error. These are logged in /var/log/ltm.
    Since you have the "elseif" listed on a new line, I might suspect you are running into the whitespace problem documented in these posts:
    http://devcentral.f5.com/default.aspx?tabid=28&view=topic&forumid=5&postid=2073
    http://devcentral.f5.com/default.aspx?tabid=28&view=topic&forumid=5&postid=2033
