Technical Forum
Custom Alert Banner
LTM Monitor shows no Instance but Nodes
kgaigl
Cirrocumulus
Cirrocumulus
Hello,
One of the Monitors shows in the "Instance"-tab no pool but some of the nodes.
Also the Server Admin told me, that the Healthchecks ate still running.
I know I recently did some changes in monitoring but if I change the monitoring of a pool, the the old monitor is not in use.
The Nodes have all standard-settings, no special monitoring activated.
by chance, I've uploaded a qkview to ihealth (for another Reason) and the affected Monitor is not in the List of Unused Objects.
Any Ideas where to look?
Oh, Version is 14.1.4.4
3 REPLIES 3
Hello kgaigl.
Use this next command (from bash) to figure out what objects are using this monitor.
tmsh -q -c "cd / ; list recursive one-line" | grep <monitor_name>
Regards,
Dario.
kgaigl
Cirrocumulus
Cirrocumulus
Hello Dario,
thanks, I found a Pool and I'm wondering, why in Monitors -> Instances the Pool is not listed.
But thats at the moment not our Problem:
On Monday after the Problem I switched to the Standby BIG-IP and rebootet the Active One, but the BIG IP fails to reboot (Restarting Tomcat) ☹️
opend already a Support Case
Yep, something this happens 🙄
BTW, please don't forget to give some thumbs up or mark the response as "resolved" to let other users find it.
Regards,
Dario.
