06-May-2020 11:46
Hi everyone,
I'm trying to load balance tableau service.
I'm currently using apps.domain.com/ for multiple applications. The Vserver has an irule configured that assigns a different pool depending on the uri that the user specifies.
Example
apps.domain.com/app1
pool1
apps.domain.com/app2
pool2
I want to add tableau to the same vserver like this apps.domain.com/tableau but tableau doesn't use a uri, and the load of the application fails.
How can i mask tableau service using the uri /tableau even if in the tableau server that uri doesn't exist.
regards,
06-May-2020 13:11
Question: would you need to rewrite responses from the tableau server?
If you do not need to replace values within the server response, then devcentral has an article about URI masking
If you follow the exampl from the article: Your irule will likely get a performance benefit from using HTTP::path instead of HTTP::uri. It is just less characters to process, no huge benefit.
07-May-2020 11:54
Thank you for your prompt response.
For tableau to work correctly, it use multiple URI's.
some of those are:
server01/#
server01/vzql
server01/t
How can i modify the iRule code to work for what I need
set HOST [string tolower [HTTP::host]]
set URI [string tolower [HTTP::uri]]
if { $HOST contains "devtest.domain.com" } {
#Disable SSL
SSL::disable serverside
if { $URI contains "/wdev/wweb.ll?wsession" } {
HTTP::uri [string map {/wdev/wweb.ll?wsession /wdev/wweb.ll?FoldSession} [HTTP::uri]]
pool POOL-DEV2
when HTTP_RESPONSE {
if { [HTTP::header values Location] contains "/wdev/wweb.ll?FoldSession" } {
HTTP::header replace Location [string map {/wdev/wweb.ll?FoldSession /wdev/wweb.ll?wsession} [HTTP::header value Location]]
