29-Apr-2020 01:54
We just configured F5 for printing load balance(standard VS, Not DSR). Loopback adoptors have been installed in 2 printer servers and run the netsh on interfaces.
netsh interface ipv4 set interface "Ethernet1" weakhostreceive=enabled
netsh interface ipv4 set interface "Loopback" weakhostreceive=enabled
netsh interface ipv4 set interface "Loopback" weakhostsend=enabled
Server registry DisableLoopbackCheck=1 has been done
Installed the same print queue to both print servers
All print queues can be browsed but not able to connect to and returned windows 0000079 errors.
Is it the problem on the LTM configurations? or missing something in print servers?
29-Apr-2020 02:06
You're going to have to provide more information than this - I suggest you start by looking at statistics to see whether the VS is being used and traffic sent to the backend server. If this doesn't show anything then you can run tcpdump to see the actual data being sent and you should be able to trace whether the issue is with LTM or not.
05-May-2020 21:06
LTM can handle the 445 & 135 but not the Windows printing dynamic ports range 49152-65535
10.x.x.x(my pc IP):60450 10.x.x.x(LTM VIP):445 10.x.x.x(LTM VIP):60450 10.x.x.x(print server IP):445 tcp 0 (tmm:1) none
10.x.x.x(my pc IP):60488 10.x.x.x(LTM VIP):49162 10.x.x.x(my pc IP):60488 10.x.x.x(LTM VIP):49162 tcp 1 (tmm:0) none
LTM has been configured with the port 135 & 445 only. Does it require to config more ports in LTM?
ltm pool xxxxx_135 {
description "xxxxx"
members {
printserver1_10.x.x.A:epmap {
address 10.x.x.A
description "xxxxx"
session monitor-enabled
state up
printserver2_10.x.x.B:epmap {
address 10.x.x.B
state up
monitor tcp
ltm pool xxxxx_445 {
description "xxxxx"
members {
printserver1_10.x.x.A:microsoft-ds {
address 10.x.x.A
description "xxxxx"
state up
printserver2_10.x.x.B:microsoft-ds {
address 10.x.x.B
description "xxxxx"
state up
monitor tcp
06-May-2020 03:17
