31-May-2021 14:58
Hello ,
I am facing issue while fetching VIP details from CLI and GUI.
As i am getting 256 VIP (availability as Available and Offline both) on CLI while on GUI getting 259 VIP.
Why this occurs and how we can fix this difference in VIP count.
PS-My F5 LTM appliance is running on 12.1.5.2 image.
GPG
01-Jun-2021 08:27
Do you have partitions as maybe in the GUI some of the vip are under another partition?
https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/tmos-concepts-11-5-0/8.html
Also you only LTM right as APM has some default VIP servers that start with "__"?
11-Jun-2021 05:17
No , We are not using Partition .
13-Jun-2021
22:28
- last edited on
21-Nov-2022
16:18
by
JimmyPackets
This is interesting, can you share us the snapshot of GUI network map and also the below command,
Put the below code in a /var/tmp/virtual-status file. And simple run it by bash /var/tmp/virtual-status
tmsh show ltm virtual > /var/tmp/virtual-status
echo -n "Total Virtual Servers : " ; cat /var/tmp/virtual-status | grep Availability | wc -l
echo -n "Virtual Servers Available : "; cat /var/tmp/virtual-status | grep "Availability : available" | wc -l | tr -d '\n'; echo -n " (Disabled: ";cat /var/tmp/virtual-status | grep -A1 "Availability : available" | grep disabled | wc -l | tr -d '\n' ; echo -n ")";
echo -ne "\nVirtual Servers Unavailable : "; cat /var/tmp/virtual-status | grep "Availability : unavailable" | wc -l | tr -d '\n'; echo -n " (Disabled: "; cat /var/tmp/virtual-status | grep -A1 "Availability : unavailable" | grep disabled | wc -l | tr -d '\n' ; echo -n ")";
echo -ne "\nVirtual Servers Offline : "; cat /var/tmp/virtual-status | grep "Availability : offline" | wc -l | tr -d '\n'; echo -n " (Disabled: "; cat /var/tmp/virtual-status | grep -A1 "Availability : unavailable" | grep disabled | wc -l | tr -d '\n' ; echo -n ")";
echo -ne "\nVirtual Servers Unknown : "; cat /var/tmp/virtual-status | grep "Availability : unknown" | wc -l | tr -d '\n'; echo -n " (Disabled: "; cat /var/tmp/virtual-status | grep -A1 "Availability : unavailable" | grep disabled | wc -l | tr -d '\n' ; echo -n ")";
14-Jun-2021 07:13
Nice script jaikumar_f5 ! I will also copy it for some automations. If there is a real difference maybe the web can be restarted with bigstart restart httpd/tomcat or even "mcpd reload" as there could be discrepancy between the GUI and bigip.conf but your script will confirm that.
