Jim_M's avatar
Jim_M
Icon for Cirrus rankCirrus
Jan 13, 2021
LTM device management - syncing all objects
I have two 15.1.2 bigIP in Azure in a load balancer sandwich operating as active/active. I would like to sync all objects - including traffic objects - between the two. The doc says i should use a sync-only device group. I have established that, but objects are not syncing. Other doco says that traffic objects are only synchronised when traffic groups are used, and traffic groups require sync-failover. How would i sync all objects in the 'common', and any additional, partitions? Can you advise as to how?
  • Hello Jim.
    You can use Sync-Only to synchonize specific partitions (folders) between devices.
    https://clouddocs.f5.com/training/community/adc/html/class2/module1/lab2.html
    https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/bigip-device-service-clustering-admin-11-6-0/4.html#unique_602443707
    Check inside of your partitions, you will see an option to associate a specific device-group to that partition.
    Regards,
    Dario.
