Sort By
- Faruk_AYDINNimbostratus
If the applications are web-based apps, then use L7 ACLs.
Hello,
I would like to know if its possible to create an LTM Policy/iRule/APM VPE that restrict access for some application based on Dynamic IP using that changes frequenly, so i need to create a rule using the hostname/FQDN. I tried to create an entry in datagroup, but its seems that its update the value to an static IP. What options do i have to achive this?
https://support.f5.com/kb/en-us/products/big-ip_apm/manuals/product/apm-network-access-13-0-0/3.html
https://devcentral.f5.com/articles/apm-security-protecting-internal-resources-using-acls
