18-Dec-2018
01:52
- last edited on
01-Jun-2023
16:28
by
JimmyPackets
We've running an iRule on v13.1.0.6 which works fine. After upgrading to v14.1.0 the same iRule causes an error:
err tmm[11570]: 01220001:3: TCL error: /Common/test_ir_asm_error-page - ERR_NOT_SUPPORTED (line 2) invoked from within "HTTP::query"
Here's the responsible part of the iRule:
when HTTP_REQUEST
set mainPath "show-error-page"
set mainPathExists "FALSE"
set httpQuery [HTTP::query]
set httpUri [HTTP::uri]
set httpUrlMin [call ir_asm_library::getMinimalizedUrl]
if {$httpUri contains $mainPath}
set mainPathExists "TRUE"
set iFileErrorPageName [URI::query [HTTP::uri] "page"]
Why we can't call [HTTP:query] , [HTTP:uri] or [HTTP:host] within a HTTP_REQUEST event anymore?
UPDATE:
We already solved the problem. This issue was caused by another iRule which is attached to the same vServer (executed before) and uses HTTP::respond in order to answer with a css-file used by the asm error page.
The following iRule
when HTTP_REQUEST
switch -glob [string tolower [HTTP::uri]] {
"/css/if_css_e.css" {HTTP::respond 200 content [ifile get if_asm_css_e] "Content-Type" "text/css" }
"/css/if_css_e_ext.css" {HTTP::respond 200 content [ifile get if_asm_css_e_ext] "Content-Type" "text/css" }
"/css/if_css_ee.css" {HTTP::respond 200 content [ifile get if_asm_css_ee] "Content-Type" "text/css" }
was replaced by:
when HTTP_REQUEST
"Connection" "Close"
event disable all }
event disable all }
event disable all }
Is this a bug in v14.1 or a bug in in the iRule which was tolerated by v13.1.0.6 and v14.0.0 ?
27-Dec-2018
03:29
- last edited on
22-Nov-2022
15:17
by
JimmyPackets
You may not evaluate HTTP request after you execute a HTTP::respond or HTTP::redirect... F5 only enforced this in new versions.
In version 14.0, F5 introduced a new command to prevent this issue : HTTP::has_responded
try this code to leave the irule if another one made this one invalid.
if {[HTTP::has_responded]} {return}
22-May-2019 14:00
Using "event disable all" followed by "return" is no longer sufficient under v14.1? Only the `HTTP::has_responded` method?
I was previously accomplishing this behavior by putting those two commands in any iRule where I sent a response, but maybe there is a separate issue (like I need to do a log before the redirect first?)
09-May-2019 08:28
The problem I have here is that a simple http redirect to https causes the above "issue"
18-Aug-2019 22:12
For the future, it was the final statement. I had logging statements which previously worked but were broken by the upgrade to v14. I corrected this in the standby unit for testing and my "event disable all > return" technique continues to work.
Strangely, I do not have HTTP::has_responded available to me (at least in the editor showing syntax) in 14.0 or 14.1, so I'll have to check with support about that.
