Technical Forum
Loadbalance a URL to 3 URLs
ASMAPMLTM
Altostratus
Altostratus
Hi Guys,
I have a requirement like
if { [HTTP::path] equals "/exampletext"
it should loadbalance/roundrobin the redirection to 3 URLs shown below
"https://abc1ee.xyz.com/exampletext_1"
"https://abc2ee.xyz.com/exampletext_2"
"https://abc3ee.xyz.com/exampletext_3"
Kindly, help ! TIA
6 REPLIES 6
ragunath154
you can use the RAND funtion in irule ,try below irule
# Generate a random number between 1 and 3
set random_num [expr {int(rand() * 3) + 1}]
if {[string tolower [HTTP::path]] eq "/exampletext"} {
HTTP::redirect http://abc$random_num\ee.xyz.com/exampletext_$random_num
Paulius
MVP
MVP
@ASMAPMLTM you can use @ragunath154 example but that will be random load balancing using the random function rather than round robin. Why do you have the requirement to load balance the host portion rather than allowing the use of 1 host and then load balancing to all servers that would handle request from the 3 seperate hosts?
Well I agree this scenario is different than the ideal solution. Its what application team is pushing.
Is this something related with Openshift service url. Because I'm getting confused when you say redirect. Do you want redirect or host header modify & send the traffic to your respective servers which handle each domains.
Its redirection only.
ASMAPMLTM
Altostratus
Altostratus
This worked, but dont sometimes it fails out of nowhere
when RULE_INIT {
set ::c 0
event enable
switch $::c {
0 {
HTTP::redirect "https://abc1ee.xyz.com/exampletext_1"
incr ::c
event disable
1 {
HTTP::redirect "https://abc2ee.xyz.com/exampletext_2"
incr ::c
event disable
2 {
HTTP::redirect "https://abc3ee.xyz.com/exampletext_3"
set ::c 0
event disable
