Technical Forum
List of Load Balancing Mode values for iControl Rest API Call
Sarath_Chandra
My name is Sarath, we are working on Automating the F5 LTM Pool / Pool Members / Monitor Creation using F5 API Calls. I am trying to find the different Load Balancing Mode values available that can be passed to the api call. I am unable to find any documentation for it. The only document available is the API call Reference. Please provide a link to all the Load Balancing Mode values available. Really appreciate your help on this.
Link Available for API Ref: https://clouddocs.f5.com/api/icontrol-rest/APIRef_tm_ltm_pool.html
Sarath Chandra
1 ACCEPTED SOLUTION
Satoshi_Toyosa1
F5 Employee
F5 Employee
You can find the list of load-balancing methods from tmsh help. Run the command below from your console:
# tmsh help ltm pool
The command yields
load-balancing-mode [
          dynamic-ratio-member | dynamic-ratio-node |
          fastest-app-response | fastest-node |
          least-connections-members |
          least-connections-node |
          least-sessions |
          observed-member | observed-node |
          predictive-member | predictive-node |
          ratio-least-connections-member |
          ratio-least-connections-node |
          ratio-member | ratio-node | ratio-session |
          round-robin | weighted-least-connections-member |
          weighted-least-connections-node]
You can get the same information from the Configuration Utility (GUI) too: Just click the Help tab.
You can do the same with iControl REST, however, there is no direct iControl REST API for tmsh help, unfortunately. So, you need to call /mgmt/tm/util/bash to call tmsh to get a desired help (I know, it's awkward).
# curl -sku admin:<pass> https://<mgmtIP>/mgmt/tm/util/bash \
  -X POST \
  -H "Content-Type: application/json" \
  -d '{"command":"run", "utilCmdArgs":"-c \"tmsh help ltm pool\""}'
You may want to pipe the output to the following python one-liner for readability:
| python -c 'import sys,json; o=json.load(sys.stdin); print o["commandResult"]'
I hope this helps.
2 REPLIES 2
Satoshi_Toyosa1
F5 Employee
F5 Employee
The command yields
          least-sessions |
  -X POST \
I hope this helps.
Hi Satoshi,
Thank you so much for the quick response. This is really helpful.
Sarath Chandra
