Technical Forum
Limiting closed port RST response from 501 to 500 packets/sec for traffic-group/Common/trafficgroup1
ikkut23
Altostratus
Altostratus
Hi Guys,
I have read the following KB https://support.f5.com/csp/article/K13151 about TCP RSTs, i`m in situation when i get on ltm the following logs
Limiting closed port RST response from 501 to 500 packets/sec for traffic-group /Common/traffic-group-1
followed with high peak of analysis plane around 100% at that time.
Does this indicate a Dos/DDos attack or smth else.
Thnx in advance
1 REPLY 1
Hi @ikkut23 ,
Did you check these KBs : https://support.f5.com/csp/article/K91152308 , https://support.f5.com/csp/article/K42827106 before.
Also ( open Virtual server statistics , and check the highest virtual server consumes your Cpu.)
_______________________
Regards
Mohamed Kansoh
