Technical Forum
License
TriAngel
Hi
我现在想在自己电脑搭建F5实验环境学习,我应该激活哪个Key?
图片中的5个Key分别是什么作用?
2 REPLIES 2
Hi TriAngel,
You can use the first 3 for BIG-IP on 3 different Virtual machines. If only one device is sufficient, you can use either 1,2 or 3.
T-Trust
MVP
MVP
Hi Triangel,
You can use number 1 for BIGIP System like load balance, DNS system, for number 4, 5 that's license about F5 management system, Please find step add license below,
https://cloud-ttrust.com/how-to-add-or-reactivate-license-on-f5/
i hope this information will help you
Thanks you
