Technical Forum
LCM Bigip 4200 LTMs
Ashu_Aggarwal
Cirrus
Cirrus
I have to LCM 4200 LTMs deployed in my company. We are planning to replace them with newer 4000 models. my question is regarding config upload. Is it possible to upload the ucs file of 4200 to 4000 appliances? Would it work? What is best way to migrate the config (VSs, pools. policies etc) from one model to another HW model.
4 REPLIES 4
Yes that is possible. (You could follow this article https://support.f5.com/csp/article/K12880 )
You could also install the same software version on all 4.
Create a cluster of 4 BIG-IP's (this is possible with different hardware, provisioning must be the same).
If the new members are functioning as expected, remove the two old BIG-IP's from the cluster.
Cheers,
Kees
Ashu_Aggarwal
Cirrus
Cirrus
Thanks for your guidance. I found this solution article & we are running on version 15.1.0.4 but our version is not listed under applies to section. Do you think it would work?
K15496: Migrate a device group member to a new BIG-IP hardware platform
Ashu_Aggarwal
Cirrus
Cirrus
https://support.f5.com/csp/article/K15496
Yes it will work.
Cheers,
Kees​
