Kubernetes F5 container connector
I've successfully deployed the F5 container connector to my on-prem kubernetes cluster. all seems to be good, it reports ready and available. Deploying new apps, the pools and vips defined in my config map don't appears on my BiGIP VE. Any other BigIP requirements. i've accounted for the following
- new partition - kubernetes
- admin privileges in kubernetes secret
A couple questions.
From the bigip container deployment yaml: "--bigip-url=10.1.2.10" - refers specifically bigip mgmt interface on can it be any selfip or floating-ip?
anyway to troubleshoot and verify that kubernetes bip controller can successfully update my ltm.
any help would be much appreciated
- Nath
Up!
