Ankur_Mathur's avatar
Ankur_Mathur
Oct 22, 2018
Issue using Ansible BIGIP_UCS module
I am trying to upgrade the software image on a BigIP VCMP guest using ansible. While I am able to perform almost all the tasks, the installation of UCS file(module used: bigip_ucs) is not getting complete. The task gets stuck and never proceeds further. However, on checking the system the installation seems to have completed with the system waiting for sync(next task in playbook). Can someone suggest how to proceed further? Following is the sequence of tasks that I am doing.
  1. Fetch the master key from vm (Module: bigip_command)
  2. Set the hostname (Module: bigip_hostname)
  3. Download a new UCS file (Module: bigip_ucs_fetch)
  4. Shut down current Guest (Module: bigip_vcmp_guest)
  5. Delete the vcmp guest & delete the virtual disk (Module: bigip_vcmp_guest)
  6. Create a new guest (Module: bigip_vcmp_guest) Power Up new guest (Module: bigip_vcmp_guest)
  7. Set the hostname (Module: bigip_sys_global)
  8. Login and Disable initial config (Module: bigip_sys_global)
  9. Save the running configuration of the BIG-IP (Module: bigip_config)
  10. Provision modules (Module: bigip_provision)
  11. Reinstate the master key (Module: bigip_command)
  12. Upload & Install the UCS file (Module: bigip_ucs) ---- This is where the playbook hangs
  13. Sync Group (Module: bigip_configsync_action)
  14. Remove the uploaded UCS file (Module: bigip_ucs)
  • Following is my playbook:
    (f5_poc) -bash-4.2$ cat f5_upgrade.yaml
    • hosts: f5 connection: local gather_facts: False vars_files:
      • creds.yml
      • "{{upgrade_info}}"
    tasks:
      Configure User
      - name: Configure User
        tags:
           - run
        set_fact:
           provider:
              user: "{{username}}"
              password: "{{password}}"
              validate_certs: no
           admin_user:
              user: admin
              password: admin
              timeout: 360
              validate_certs: no
        delegate_to: localhost
      Fetch the master key from the vm
      - name: Fetch the master key from vm
        tags:
           - run
        bigip_command:
           provider: "{{provider}}"
           server: "{{ ip_addr }}"
           commands: shell f5mku -K
        register: cmd_output
      - name : Setting the master key
        tags:
           - run
        set_fact:
           master_key :  "{{ cmd_output.stdout | regex_replace('^..|..$', '') }}"
       Download the software image on host
      - name: Upload the software image on host
        tags:
           - dont
        bigip_software_image:
           image: /tmp/BIGIP-12.1.3.7-0.0.2.iso
           server: 172.18.224.4
           force: yes
           state: present
           server_port: 443
           transport: cli
           ssh_keyfile: /afs/athena.unimelb.edu.au/user/a/ankurm/.ssh/known_hosts
       Set the hostname
      - name: Set the hostname
        tags:
          - run
        bigip_hostname:
           server: "{{ip_addr}}"
           hostname: "{{vm_to_upgrade}}.unimelb.net.au"
           validate_certs: no
       Create the UCS file to restore at the end
      - name: Download a new UCS file
        tags:
           - run
        bigip_ucs_fetch:
           server: "{{server_name}}"
           src: "{{ vm_to_upgrade }}-init.ucs"
           dest: "/tmp/{{ vm_to_upgrade }}.ucs"
       Shut down current Guest:
       modify vcmp guest lb1-266-1-dev state configured
      - name: Shut down current Guest
        tags:
          - run
        bigip_vcmp_guest:
           state: disabled
           mgmt_address: "{{ ip_addr }}/{{ nw_bits }}"
           mgmt_network: bridged
           mgmt_route: "{{gateway}}"
       Delete Guest:
       delete vcmp guest lb3-396-2-dev
      - name: Delete the vcmp guest & delete the virtual disk
        tags:
           - run
        bigip_vcmp_guest:
           state: absent
           delete_virtual_disk: yes
        Create new Guest:
      - name: Create a new guest
        tags:
          - run
        bigip_vcmp_guest:
           state: configured
           allowed_slots: "{{allowed_slots}}"
           number_of_slots: "{{number_of_slots}}"
           min_number_of_slots: "{{min_number_of_slots}}"
           cores_per_slot: "{{cores_per_slot}}"
           initial_image: "{{sw_image}}"
           vlans: "{{vlans}}"
        Power up the Guest:
      - name: Power Up new guest
        tags:
          - run
        bigip_vcmp_guest:
           state: present
       Set the hostname
        tags:
          - run
        bigip_hostname:
           provider: "{{admin_user}}"
       Disable Initial Setup of the guest
      - name: Login and Disable initial config
        tags:
          - run
        bigip_sys_global:
           gui_setup: no
       Save running Config
      - name: Save the running configuration of the BIG-IP
        tags:
          - run
        bigip_config:
           save: yes
       Provision Modules
      - name: Provision modules
        tags:
          - run
        bigip_provision:
           module: "{{item}}"
           state: present
           level: nominal
        loop: "{{provision_modules}}"
      - name: Reinstate the master key
        tags:
           - run
        bigip_command:
           commands: "shell f5mku -r {{master_key}}"
           commands: shell f5mku -r GZIwzAaSeTu/EIcOHqT7FQ==
       Upload and install the UCS file
      - name: Upload the UCS file
        tags:
          - run
        bigip_ucs:
           force: yes
           state: present
           ucs: "/tmp/{{ vm_to_upgrade }}-init.ucs"
      - name: Install the UCS file
        tags:
          - run
        bigip_ucs:
           force: no
           state: installed
           no_license: yes
           no_platform_check: yes
           include_chassis_level_config: no
      - name: Sync Group
        tags:
           - run
        bigip_configsync_action:
           device_group: "{{item}}"
           sync_device_to_group: yes
           server: "{{sync_device}}"
           overwrite_config: yes
        loop: "{{sync_groups}}"
      - name: Remove the uploaded UCS file
        tags:
          - run
        bigip_ucs:
           state: absent
           ucs: "{{ vm_to_upgrade }}-init.ucs"
  • thank you for sharing.
    I am facing issue with ISO-upload task. it times out after certain size of the image/ won't finish uploading entire image.
    I work over VPN and using wireless connection. However I am able to upload same iso via GUI. which tells me that it's not connection issue. Must be something related to upload big file using ansible over vpn and wireless connection.
    any idea what tunning do I need to do to make it work using ansible?
  • Hello Ankur,
    The first thing I would do is enable debug mode in ansible.
    More specifically, I might try is adding a timeout to your ucs upload and ucs install plays. This would let you know if your ucs plays are actually failing or if they're installing the config like it seems on the big-ip.
    I'd also throw a timeout on your config-sync play; if the ucs plays are actually working, then it seems like the playbook is actually hanging on the sync play, not the ucs plays.
    That's all I can think of for troubleshooting off the top of my head. Let me know if you figure it out!
    best of luck,
    Austin
