29-Sep-2022 03:41 - edited 29-Sep-2022 06:54
I first deploy a simple HTTP application using AS3 (with 2 pool members A and B) , then I make a change on GUI to delete a pool member B from the pool , then I make further change [PATCH] using as3, e.g. add a new pool member C to the pool. However, the last AS3 deployment will revert my change made on GUI (i.e. the deleted pool member will be added back and now there are 3 members (A+B+C) in the pool, but it supposes to be 2 members only (A and C) .
Is there any parameter/value I can set on AS3 body so that it will not revert the change I made on GUI?
29-Sep-2022 18:31
So , it means that any changes made on the GUI wouldn't affect the data/ array of AS3 template (i.e. if we update pool configurations on GUI, we must also update the config via AS3 as well )?
29-Sep-2022 18:42
As after I delete the pool member B on GUI, then I simply add a new pool member C via AS3 directly as follow.
PATCH
[ { "op": "add", "path": "xxxxxxxx/web_pool/members/-", "memebers":
"Serviceport":80
"ServerAddress": member C IP } ]
