12-May-2023 07:00
Hello dears
When upgrade my device from 17.0.0 to 17.1.0 i got the following error "The configuration has not yet loaded. If this message persists, it may indicate a configuration problem"
could you help me plz take in mind the configration on the device had gone
series of the device is 4600 and also i saw all module are not licesned
Bests
12-May-2023 13:44
@MustphaBassim It is possible that your service check date is incorrect and you will need to have that updated before moving to the next code version. The following articles should help you in verifying and updating the service check date.
16-May-2023 21:21
@MustphaBassim - did @Paulius help? If yes, please click Accept as Solution so future users can easily find the answer they need! 🙂
