20-Jun-2020 01:25
Hi! Experts
Sorry for disturbing, we need migrate some cofiguration from one Azure F5 VM to another F5 VM manually, but need modified some configuration first, is there any way to do this? it seems ucs file cannot be modified.
is there any experience and could shed some light on this?
Thansk for your help.
20-Jun-2020 17:29
A UCS is basically an archive of the config directory, so you can unpack it and change the config if you want to migrate it. If you want to export config, you can also run the tmsh command eg 'tmsh list ltm virtual xyz', store that in a file and load the config using tnsh load sys config merge file /var/tmp/<filename>
