Technical Forum
Is it possible to prevent BIG-IP to send TCP RST?
TeemuK
Altostratus
Altostratus
Hello,
I was wondering if it is possible to prevent the big-ip system to send TCP RST to connections / ports that are not actually in use? This is a problem when scanning etc activities occur towards services.
BR
Teemu
3 REPLIES 3
Hi @TeemuK ,
Could you be more specific about why you want to prevent TCP resets? because the F5 is a deny device by default, if the port is not open it have to send a reset as a firewall, in the case you want to allow all port in a virtual server you have to configure the port in 0 in the virtual server.
check TM.rejectunmatched from this article
https://my.f5.com/manage/s/article/K9812
So basically case resolved 🙂
