Bhupendra's avatar
Bhupendra
Jun 20, 2023
Solved
irule
I want to put below condition on irule, please help
1. If source IP matches and URI is /A  and /B traffic should be forwarded to POOL A
2. If user is accessing /C-new, rewrite URI to /C and forward to POOL A
3. if not matches 1 and 2 condition defalut POOL B
  • Hi Bhupendra ,
    in Step 2 of rewrite >>> do you need the source ip matches as well or Not ?
    So you need to match on specific source IP address/address first and then match /A or /B then move traffic to pool A but if the same match on source ip address/addresses but with uri starts with /c-new modify it to be /C and forward traffic to pool A
    if non of those forward to pool B
    that's Correct ?
    • Bhupendra's avatar
      Bhupendra
      Hi Mohamed_Ahmed_Kansoh
      in Step 2 of rewrite >>> do you need the source ip matches as well or Not ? ------- >>>>No we don't want to match source IP here only URI with any source.
      that's Correct ? ----------------->>First condition match on specific source IP address/address first  then match URI /A or /B for selected source IPs then move traffic to pool A
      Second condition -any source with uri starts with /c-new modify it to be /C and forward traffic to pool A
      If no condition match from 1&2 then default traffic should be route POOL B
      • Hi Bhupendra ,
        Use this irule :
            if { ( [IP::addr [IP::client_addr] equals x.x.x.x ] ) and ( ([HTTP::uri] starts_with "/A") or ([HTTP::uri] starts_with "/B" ) ) }{
                log local0. " First Condition matched >>>> GO TO POOL A 🙂 "
                pool POOL_A
            } elseif { ( [HTTP::uri] starts_with "/C-new" ) }{
             HTTP::uri [string map -nocase {"/C-new " "/C"} [HTTP::uri]]
               log local0. " 2nd Condition matched (String MAP did it work ) >>>> GO TO POOL A 🙂 "
               pool POOL_A
            log local0. " 3rd Condition matched ( Default path ) >>>> GO TO POOL B 🙂 "
            return
        Don't forget to assign POOL_B as a default pool in Virtual server resources , to forward traffic in case the last condition ( Default ) triggered.
        >> Also Make sure that there are no multiple requests are sent for each web page.
        I mean :
        if you sent req like this http://10.10.10.10/A by the specified source address it should be forwarded correct to pool_A.
        But what if at the same time your web page needs multiple requests like http://10.10.10.10/image.php
        so make sure you send only single request per page.
        Goodluck
  • Maybe think about using a local traffic policy rather than an iRule. It will be more efficient and easier for you to manage
