17-May-2017
05:29
- last edited on
03-Jun-2023
11:22
by
JimmyPackets
Hi all,
So we have a situation where we are using the BIG-IP to act as an RDP gateway to two separate domains.
So basically a single workstation can RDP into two separate domains. We need the F5 to resolve IP addresses to the correct hostname.
Now this works perfectly fine for the first DNS server + domain in our list as configured by System > Configuration > Device > DNS.
However the 2nd domain fails as I don't think the requests reach the 2nd DNS server.
I am wondering if there is an iRule we can create that will route certain destination IP/hostnames to a certain DNS server for resolution.
This is what I tried to create myself but I think I may have been slightly off...
when DNS_REQUEST {
if { [IP::client_addr] starts_with "10.10.10." } {
switch -glob [string tolower [DNS::rrname]] {
"domain1.com" -
pool DNS_1
default {
pool DNS_2
So i'm trying to point anything looking for domain1.com to DNS_1 pool and everything else to DNS_2 pool...but I think I may be completely off base!
Are there any iRule wizards that can assist?
Thanks!
18-May-2017 02:24
I don't think iRule is the correct tool for this problem.
Based in your iRule, the user is sending the query. However, you are talking about the DNS configured for the BIG-IP itself. So, who needs to query those names?
What modules do you have in the unit?
What version are you using?
