12-May-2020 10:22
I need to increase a tcp timeout value. when a certain client connects to VIP. I did this:
when CLIENT_ACCEPTED {
if { [IP::addr [IP::client_addr] equals 10.10.10.10] } {
TCP::idletime 600
But it resulted in an error:
"increase_idle_timeout:3: error: [undefined procedure: TCP::idletime][TCP::idletime 600]"
On the other hand this was accepted:
IP::idle_timeout 600
What is the difference between IP::idle_timeout and TCP::idletime?
I'm running 11.5.7
Solved! Go to Solution.
15-May-2020 06:53
Wrong event - the TCP::idletime fires perfectly after SERVER_CONNECTED
15-May-2020 06:53
